TacticalDoc
- 26
- 18
- Otisville MI
I understand this but if all seals are good you should be able to go through water up to the cab easy
that's what I thought ...don't plan on going deep but if there is a flood and I have to ford I want to know that its capableYesterday I drove my truck through water up to the tires not that I wanted to but that I had to. Mine has the fording kit on it and it did fine but I will have to check all the fluids and make sure no water got in anywhere. The air cleaner got under water and I saw no sign of water entering it so the seal must have worked. Under an emergency situation these trucks will go through some pretty deep water.
The system gets compressed air from a regulator mounted by the air horn, when you pull the dash valve it closes of the atmospheric vent and then opens anther valve to pressurize the system.Rkurg correct me if i am wrong but it looks like from your photo they are using the pressure from the crankcase vent as the source of the pressure to pressurize everything else, is that correct? If that is not the source of the pressure then where does the truck get the air pressure from to pressurize everything, is there a hook up to the air compressor that i can't see in your photo. Now does that knob on your dash that you pull to work the system connect to those two ball valves in your photo?
When the fording valve is in the fording pisition the crankcase breather tube is shut down. This is another reason they want you to release the valve right after fording as the crankcase pressures will build up.Rkurg correct me if i am wrong but it looks like from your photo they are using the pressure from the crankcase vent as the source of the pressure to pressurize everything else, is that correct? If that is not the source of the pressure then where does the truck get the air pressure from to pressurize everything, is there a hook up to the air compressor that i can't see in your photo. Now does that knob on your dash that you pull to work the system connect to those two ball valves in your photo?
