Microsoft MSN, Live, Hotmail, Outlook email users may not be receiving emails. We are working to resolve this issue. Please add support@steelsoldiers.com to your trusted contacts.
Unless in its life before me it was abused, then no idea. My only guess was a defect in the gear from the start.
I was on flat a road, not towing anything, gear oil was at the correct level and not being stupid with the throttle.
So if it was something I did I sure can not figure it out.
Edit to add. My father is a metalurgist so I am going to try to get the damaged gear to him to see if he can see where the fracture started.
Those gears didn't fail without a very significant reason. It looks like the straight cut gear failed because it wasn't fully meshed when the load was applied. I don't have a guess on the other. Also, parts don't necesswarly just settle to the bottom. There is significant agitation in there, at roadspeed. Uncle Sam didn't go to automatic transmissions, without good reason.
I assume you mean on a used shaft. with all that metal running around in the oil, I doubt the bearings were in usable shape, but you will be the first to know!
Well Tom, I decided to take your advice and change all bearings. The old felt good, but there was just too much uncertainty the more I thought about it. Thanks
