- 806
- 200
- 43
Hey All,
Did some searching about this, but didn't find anything specifically.
The Background: We're still trying to find a place to move to, and we have now driven the deuce about 4500-5000 miles over the last 8-9 months, pulling a trailer, plus about 9,500lbs in the bed.
The Problem: A few days ago, we were pulling out of a truck stop, when my Dad thought the transmission went out. He had no power etc. Looking closer, we found the transfer case had popped into neutral. Dad thought he might have just happened to bump it somehow or ? Everything seemed fine.
But Yesterday, we had it happen several more times over the course of about 60 miles.
Related?: We've been leaking a bit of oil (small puddle about 5-10 inches in diameter) when we park the truck, which would stop after a few minuets. This would only occur when the truck was 'up to temp', and the oil was hot, and as everyone knows it only takes a small amount of hot oil to spread around. We thought it had been just a small engine leak and always kept a check on the oil.
But now, we're wondering if it had been leaking out of the transfer case... which we're going to check.
If so, and the t-case is low: What are the chances that it just needs to be refilled with new fluid...
And it not need pulled off and torn apart?
I'm guessing the only way to know, is to refill, and drive it to see if it continues to pop into neutral.
IF the fluid is not low: Then I'm also guessing that this means there is an problem inside the t-case, and it will be necessary to pull and tear down.
Any input or experience would be appreciated!
~Thanks
~Thanks
