1800 Diesel
- 26
- 18
- Santa Rosa County, FL
Looking for others that own/operate/maintain this machine. The TM says compressor oil should be MIL-L-2104 10W. Years ago this spec was for diesel engines (usually 15/40W). Can someone cross this over to a locally available oil? I can get "compressor oil" anywhere but generally no one can address the mil-spec requirements. Also since this is a rotary compressor, I don't want to damage the compressor end with the wrong type of oil.
Not sure if either compressor end or engine is any good on this unit, but need to put oil in the compressor before I can attempt a start-up.
Thanks,
Kevin
Thanks,
Kevin
