MEP-004A parts, where?
puddlejumper
Central Minnesota
I finally got around to looking at my second (actually first one I purchased) 004A and found that I am missing several parts. Does anyone know where I could find the Manual Speed Control assembly mine is completely missing. Also I am looking for the end connector and bulb for the air filter light?
1800 Diesel
26
Santa Rosa County, FL
I have a fault indicator and matched frequency set and misc guages,2cents
I could use a battle short light assembly (red lens) & a circuit breaker light assembly (amber lens) for an MEP-004A. Also might need an AC voltage gauge. Mine seems to be stuck at about 120V--won't jump up to 240V when I switch to L1+L3...you can send me a PM if you have any of these.
Thanks,
Kevin
Coffey1
497
Gray Court SC
Thank you still need to paint the trailer. mine needed batts and all the filters and fluids but once I filled her up she fired right up had to buy a new voltage regulator it was fried put that in and she has voltage single phase her ready to go
1800 Diesel
26
I like the paint job my second unit is just plain tan, the good news is it only needed batteries and it fired right up!! I plan on keeping the 004AAS and getting rid of my 004A .
The ASK models are definitely easier on the ears than the standard MEP-004A models...kinda bulky/ugly but the sound enclosure helps quite a bit... :)
1800 Diesel
26
$30 plus shipping, I don't know about packing and it fitting in the small flat rate box though, I would want to pad it well for shipping,
part number on front is 633-16752 0-500 volts with red lines on 120/208/240/420
Is that message for me? Can you send a PM? Moderator will be calling this a classified post....
Thanks,
Kevin
puddlejumper
Central Minnesota
Mine is going to be located in my shop. That way I don't have to screw around with worrying about fuel gelling in the winter months. I will plumb the exhaust outside and the ASK keeps the noise low in the shop as well. As a back up generator it is ideal for my house and shop.
PeterD
Jaffrey, NH
As an added bonus: it will heat your shop when running under load!
1800 Diesel
26
Down here in hurricane country, that won't be a good thing since we're usually trying to keep our shops cool. But up in the snow country, I like that idea! :)
Started working on a CAD layout last night for a shed project to be built near the house that will house an MEP-004A & an MEP-003A and also (in an area separated by an insulated wall), a 300 gal fuel tank. The way our power goes out in this area (on the co-op) I told my wife that everytime a storm approaches I would switch over to the generator until the storm passes through. At least we won't be having to reset all the clocks in the house & the gensets will get an exercise on a regular basis....
