- 3,923
- 75
- 48
- Comfort, Texas
Who pressed the Blah! Blah! button?
I have original pigtails on all the lights. I also have 4 ' sections of heat shrink tubing in sizes from 1' down to 1/4" so that will encase the wires when I assemble the harness. Just waiting on the wire to finish the job. Can't afford the Zip Ties. [/QUOTE said:Suggest you make a slight mod - since you have the pigtails, put plugs on them - will make any future repairs super easy. Watch out with heat shrink. When you fit the harness into the bends, the wires should be able to slip a bit against each other. If they cannot, harness will not fit nice, and looks like . Remember, inside wire has a shorter radius and path to travel - kinda like the inside wheel in a turn. You could have all the wires cut even to say a taillight, and when you are finished fitting it in place, you will find the ends are different lengths, depending on which was on the outside and inside of the bends. Plan ahead - are you going to add turn signals? Are you going to use a more powerful horn? Look at Zout's pix - just about the best work I have seen.
You are a truly good troop Sir!! Might I recommend a nice pink zip tie?So, the wire came in today and I got the harness formed and covered and installed along the drivers side chassis rail. Terminated tailight and trailer connector wires and will start on the firewall terminations tomorrow. When I am done I will install one (1) ceremonious zip tie in honor of Commander Warp just to let him know I value his input.
So, the wire came in today and I got the harness formed and covered and installed along the drivers side chassis rail. That was FAST!!! Are you putting in any additional circuits?
