Ford Mechanic
- 6
- 38
- Edenton, NC
Subscribed, I was having high egt issues limiting the amount of throttle input also. I also changed all fuel filters with no results, tried up and down on the FDC adjust screw, tryied looseing injector lines to kill single injectors. Finally I backed the FDC adjuster all the way off untill the screw stopped moving in, added 2 flats, and adjusted droop 1/4 turn CCW. Went on a test drive didn't notice much at first and on the way back it all of a sudden opened up, EGT's went down 200*, and had plenty of power. What caused it, I don't know but I'm fixing to pull the injectors and test/adjust them.
