1800 Diesel
- 26
- 18
- Santa Rosa County, FL
Ran across a situation with a 6TL battery I got in with a genset. After trickle charging overnight (for abt 12 hrs), the battery reads a little over 12 volts, but when I connected a carbon pile load to it, the meter went to zero--as if it had no amperage at all... Usually what I find is one or two bad cells and a voltage reading of 8 or 10 volts. This is the first time I've seen a battery take a charge, read 12+ volts, but then shows no capacity when a load is applied...anyone seen this before?
