Deuce007
- 0
- 0
- North Dakota
Does anyone know where I can find one of those rebuild kits for the air assist steering cylinder?
I don't think rebuild kits are available for the cylinder. Are you sure yours needs rebuilding? If you have a problem with seals, many folks solve their problem by adding a small amount of air tool oil. Adding the oil solved all of my problems. Add the oil at the inlet port of the actuator - that way it goes through the whole system. I jacked my truck up and exercised everything by turning the wheel lock to lock multiple times.Does anyone know where I can find one of those rebuild kits for the air assist steering cylinder?
Congratulations! That was a relatively easy fixIt's fixed!! All I had to do was replace the priority valve and now the steering works flawlessly!
Yes, the A3 has the spare spare tire attach bracket, the 14.5 x 20 just fits in there.
I'm a proud owner of an A3. Let me know how I can help.
