marand9199
- 0
- 6
- willowbrook, IL
The problem; 1984 M1009 motor will not crank over. I get dash lights & GP wait light, but nothing when I turn the key to start. The Gen-1 light goes out & the water temp light comes on when I turn the key to start. Other then that nothing happens. I checked the engine fuse in the fuse block, Okay! About me, I’m more of a mechanic. Electricity & I don’t get along to well as you will find out if you read on so I need a little advise.
Here is how it all began.
I installed a new IP. After I had it in I began bleeding the fuel lines per the manual by loosening the connectors on the injectors. I cranked the motor for 8 secs and let the starter cool down then repeated. Did this 5 times with no fuel coming to the injectors. Tighten up 6 connectors and left 2 loose and tried again. Now I see fuel…good but, by this time the batteries went dead. So I put them on the charger. While charging I decided to put the intake manifold back on. While torquing the bolts I made contact to something on the fire wall near the GP relay that sparked. “CRAP” I tried to turn her over again with no problems, she cranked. & I thought I was alright. Finished buttoning up everything and went to try bleeding again and all I got was “click” “click” “click” Finished for the night I thought I would let the batteries charge over night. Next morning tried again and lights came on the dash but nothing from ignition switch. No click, nothing. That’s where I’m at. My meter went on the blink so I know I need to pick up another today.
Any and all advise on what to check will be greatly appreciated.
