warwick
- 0
- 6
- Maryland, USA
Back ground :
govliq auction truck and is in stock condition , every thing under the hood. The only thing not stock is a length of wire added by the motor pool before I bought it from auction. Wire runs from 24v bus output to resistor input. It was hooked up to the back battery negative post when I got the truck and the truck wouldn't start, moved the wire and it fired right up.
Possible problem :
Truck has been running great, no known problems. I let my brother borrow the truck and when he was done he parked it in my back yard. I went to start it the next morning for work and it would crank but not start. Brother said it drove fine and he couldn't remember doing anything wrong to cause the problem. Later said he may have gotten in the truck and cranked like you would a gas engine. He cranked right away with out waiting for the wait light, realized it after a few seconds and turned the back to run position. The wait light went out and he cranked it and the truck fired up.
What I've tried :
> checked fuel at filter bleed valve - it pumped fuel but I didn't measure output
> checked fuel at engine -pulled #1 glow plug and cranked engine and got a good mist of fuel
> batteries - new Interstate Battery 31P-MHD amps 1190 cca 950
> glow plug relay - I thought this was the problem 'cause I was getting different readings from the top(input) and bottom(output), so replaced the relay with a napa st-85 this didn't solve starting problem
> glow plugs - new acdelco 60g
I got a little frustrated and started jumping back and forth taking volt readings and trying different things, mostly just chasing my tail.
I removed the 24v to 12v resistor and pulled power for the glow plugs from the bus bar right above the gp relay.
I installed a push button switch for gp relay when I first got the truck for back up. I pulled my control card and have been using the button while trying to sort out what is wrong.
What happens now:
I turn key to run and hold the gp button for 15-20 secs, throttle half way to floor. If its cold and has sat for a day it will start and run for about 5 seconds then die. Then if I crank it for 30-45 secs with throttle to the floor wait a minute and crank 30-45 secs pedal to floor repeat one or two times and it will eventually start up. I have to feather throttle for a minute or two until it warms up. Then it will act like normal fast idle until gets up to temp. and the volt gauge climbs up to the middle of the green.
I can drive it like normal no indication of anything wrong. If I stop, the truck will fire right up while its still warm. Let it sit over night and I'm back to having to crank and crank to get it to start.
I've been pulling my hair over the glow plug system thinking that is where my problem is
Questions :
> where are the grounds on the engine block? I could only find the ground on intake to firewall near the fuel filter.
>could it be sucking air from bad hoses or another source causing the hard starting?
>other than bleeding the injectors or pulling every glow plug is there any way of check if the IP is good or not?
Thanks for any help and sorry for the long write up.
Possible problem :
What I've tried :
What happens now:
Questions :
