joeM62
- 1
- 18
- Cedartown/GA.
If by chance he doesn't have one wreckerman Twright has one at his shop.Let me call Freighttrain and see what he has. He's been parting out a deuce.
Kenny do you still have these?I had mentioned this earlier. I have 3 HMMWV 37" goodyears on 12 bolt rims. I will only pack them if presold. I will post pics in the AM. Tread guestimate is 85%, will adjust price if I'm off. Looking for $225 for the 3 of them. Need smaller tires on the -A3 trailer!
I have 2 left but no place to pack them.Kenny do you still have these?
Vinny
your link ink is down, is the truck still available?My M1009 will be at the rally ($1300). Here is a link to the classified add:
http://www.steelsoldiers.com/showthread.php?110712-M1009-Runs-Drives-w-Title-only-1300
If the dash is 5 ton it is mineHood $50 Gasser dash $35 rebuilt 24 volt alt for big truck $50 A kiss from Zout PRICELESS!!!!!!!!!!!!!!!!!!!!!!!!!
Nope its m35 2 1/2 tonIf the dash is 5 ton it is mine
Should be a Carter ETW1is that a carb that is on a civvy power wagon or do the m37s use a different carb? If it is a civvy unit, would napa have it? only problem is, I'm not coming until thursday.
I'll take it. PM sent.Do you own a mobile generator? If so, do you struggle getting the rod out of the ground when it comes time to jump TOC? Then you need a grounding rod puller outter tool. Makes the task as simple as operating a hydraulic jack. Fits nicely in tool box on a generator trailer. Using quick release pins,allows for fast disassembly of the handle which fits inside the the base for easy storage. Does not include grounding rod. I have one for sale, but could make more if there is an interest. Will trade for military stuff or $40.
