ccf460
- 1
- 18
- granite falls/N.C.
My truck has always had a fuel leak coming from the HH. After several degreasing search missions...I finally saw it leaking around the center bolt on the top of the HH. I took the bolt out , saw there was no copper washer....? Wonder how many trucks are leaking in this area. I found an o ring that fit tight around the bolt shaft. As a side note, the hole is chamfered to make room for the copper washer, so I figured the o ring would fit in there also. After installing the bolt with o ring, the fuel leak is gone. I hope this helps someone else.
