- 2,885
- 1,494
- Czech Republic
Starting again to get my steering in order. In short, left turn is without problem, right turn needs two persons to haul the steering wheel around. Hydraulic oil according TMs and recommendations here replaced and should be without air. Adjusting nut tightened to get rid of free play; worked also. Left turn right turn problem still exists.
Pics below: power steering assembly of my 1973 M51A2 multifuel
Pic left is an overview, pic right detail.
Red line: from pump
Blue line: return to reservoir
green - orange: action lines (or whatever you call them).
This set-up has some kind of link-valve above the power steering house; circled in white on the right pic. My guess is that this is a relieve valve.
There are similar threads, unfortunately without happy end or at least without a lot of pics of the actual repair.
Let's start with the dumber questions:
1) selector valve or spool valve or control valve probably all refer to the same thing, that is, part of what the TM calls the Hydraulic Control Valve Assembly?
2) this connector thingy seeming to directly link the inlet and outlet hoses is the relief or over-pressure valve?
And the key questions:
3) Could this be anything else than a problem in the Hydraulic Control Valve Assembly?
4) Is it possible to take off and repair the Hydraulic Control Valve Assembly without taking out the entire power steering assembly? Any pics or suggestions?
Unfortunately the M51A2 does not have removable lower side panels as described in the TM, so I either have to more or less take the whole fender part out or try find somebody with very small hands to work inside the engine compartment.
Red line: from pump
