UPFINN
- 4
- 18
- Ishpeming Michigan
Plan is to check the fluid when I get my 3/8 breaker bar adapter. Fluid plugs are stuck shut, and they are smaller than the 1/2 inch square drive plugs on the diffs and trans. Looking at the TMs there are only a few parts on the clutch side. Looks easy enough if I need to rebuild. I should probably check the brake adjustment on the pto side also. It looks like I will have to lift the winch off the truck after unspooling it, right?Check the fluid, it sounds like your fork is frozen on the inside. It maybe a good idea to take the winch apart to see what's in there. After you take it apart, you won't want to use the winch to pull stumps out. It is stout but the main gear inside is a light metal, I had a winch where the main gear completely broke apart. Just my 2 cents. The lever pushes a fork over that side of the drum to engage the winch, the spring lever just keeps the drum from rotating when the lever is disengaged. It doesn't have anything to do with the activation of engaging the lever.
