Joeinderry
- 1
- 0
- Derry/NH
When I turn on the main power switch only the fuel pump turns on. No low air buzzer, no lights, no charging indicator, etc....any ideas?
Thanks for any help.
A bad 3 lever wouldn't keep the low air buzzer from working.I just replaced my switch. It would only bring power if the switch was half-way between off and on. If it is your switch, then shop around--I got mine for about $50 shipped. It took less than 30 minutes to replace. Good luck.
You are correct. But, it sounds like he was describing the main power swtich to me.A bad 3 lever wouldn't keep the low air buzzer from working.
Now that I re-read that post, I can see that now. I just didn't want him buying a 3 lever when the problem seems to be before that. The master switch wouldn't affect light operation, but would affect the buzzer.You are correct. But, it sounds like he was describing the main power swtich to me.
