Hottrodd789
- 0
- 0
- Orlando fl
Has anyone put a turbo off of a LDS on to a LDT motor? eastern surplus states is will increase power by 15% !
Little things to try for one or two HP gains.I realize its its a race truck but when u run 1600 20,s a little extra power could mean the difference between downshifting or holding speed when hitting a grade! I will soon be able to tell u if there is any psi deference between c turbo and the lds turbo!
Did you buy a Turbo from Eastern?I realize its its a race truck but when u run 1600 20,s a little extra power could mean the difference between downshifting or holding speed when hitting a grade! I will soon be able to tell u if there is any psi deference between c turbo and the lds turbo!
Worth a shot. I am curious to see what your results will be.Ive installed pyro and have fuel turned up ! This is all for fun to see what works and what dosent if i wanted to i would drop in a 12v
Gimp:Little things to try for one or two HP gains.
K&N air filter, they seem to flow more than stock air filters.
Switch to an electric fan.
Find a gasser transmission to install.
Adjust your valves.
Check your injectors are clean and firing at the correct pressures.
