guner51
- 0
- 16
- Metamora, Illinois
can anybody tell me the weight of a 20,000 lbs. winch off a 5 ton
Heck, a 10K Deuce winch and accesories weighs 530#.Sorry, ain't buying 220lbs. Gotta weigh more than that. I know I had to use a 3 point lifting hitch on a tractor to load mine into the bed of a deuce.
To be used in the manner in which the TM describes.It's a self recovery winch.........
Does not look like it, the m39/m809s you canDoes anyone know if you can winch and drive a M925A1 at the same time. I cannot seem to find anything in the archives on this. I guess what I am asking is can the winch be engaged and in drive at the same time to help getting unstuck. Thanks Gary
Thank you for the clarification.To be used in the manner in which the TM describes.
With the truck in gear, the PTO output isn't going to spin at speed. Remember, that's how it's engaged. Only in neutral does the PTO spin at enough speed for the hyd. to work properly. It's not meant to be ran on the road.
That would be a no, which is nuts but true the front winch on all 939 series trucks are not for self recovery the -10 clearly states that a second vehicle with a winch is to be used to unmire a truck in deep mud. This means only a 936 can self recover with the rear winch.Does anyone know if you can winch and drive a M925A1 at the same time. I cannot seem to find anything in the archives on this. I guess what I am asking is can the winch be engaged and in drive at the same time to help getting unstuck. Thanks Gary
I must be missing something, but yes, assisting the winch for self recovery with driving wheels would be nice, (But some dufus probably had a wreck doing it wrong and therefore spoilt it for all that follow - new ruleing and soforth) BUT, what's wrong with using the winch, at full pto speed, truck in neutral for SELF RECOVERY????? - of course, snatch blocks to multiply capacity etc., when really stuck.It's a self recovery winch.........
