harleyboy1
- 0
- 6
- Lake City, Fl.
I been trying to get my CTIS working on my new toy with the help of many of you guys. I found axle oil dripping on the left rear back wheel. The air valve had popped loose from the nipple that screws into the hub. Took the nipple out,stuck my finger in the hub hole and could feel a seal just floating around. So after much reading on this great site, I decided to make the plunge and repair it myself. Of course the truck would not fit in my shop so I had to set up shop in my side yard. I did not have a axle nut socket 4 3/8 for outside nut or a 4 7/8 for inside nut. I used a brass drift punch to get the nuts off no damage to nuts at all. I used a wonder bar to pop the brake drum loose from hub and did the same for the hub. I found the center seal part number 357974TAO floating around not in its place. Upon inspection i found no damage or anything that looked unusual to me. Things looked like the truck really had only 9000 miles like the odometer says. Please take a look at the pictures and all comments are welcome..... To be continued...Thanks again, Art
