bones1
- 4
- 18
- Southern Maryland
It appears that to remove the drag link just remove cotter pins and back out threaded retainers. Am I correct?.
Thats encouraging. Though nothing ever seems to be strait forward.Sure, if it was only as easy as it sounds...
You are correct, easier if the front end is jacked up, or you have a helper in the cab.It appears that to remove the drag link just remove cotter pins and back out threaded retainers. Am I correct?.
Hmm very similar thing happened to peashooter. I sure hope that doesn't happen to me.View attachment 464193Well now, this will put a hitch in my giddyup! I will need to remedy this situation. Torque wrenched 36lbs and click.
