How have you civilized your MEP Generators?
Triple Jim
292
North Carolina
This is awesome! I was wondering if anyone would ever get around to doing this.
I was planning on a spare, too. If the price is right (may I ask what you plan to sell them for?), count me in...
Ray
It's my understanding that we're not supposed to sell things in the forums, so I'll be posting the the classifieds when I get a few more done. I am trying to keep the price down to where it will be affordable. PM me if you like, and I'll try to be more specific.
Jimc
Mullica, nj
lol its hard to get something by me like that. i notice alot of little detail stuff like that. you know what i did with the data plates probably is about the same as what you end up doing with the board layout, just the software saves in a different format.
steelypip
68
Charlottesville, VA
I'm going to throw in a 'me too' here: I only have the one generator (at the moment), and I knew I needed a spare VR board, but was not in love with the idea of getting another of the same thing with the same flaws. If I can get an upgrade, so much the better! I suggest you put a 'surveying interest' post in the for sale section and see how many replies you get. A big enough response might lead you to a group buy, board fab and PnP operation.
edgephoto
Stafford, CT
Maybe you can sell the boards with a parts list and assembly instructions. This of course would be cheaper and you could sell many more quickly. I for one would buy a board with a component list.
steelypip
68
Charlottesville, VA
As would I. You could do it like MegaSquirt, where you get a board and can order a standard BOM from DigiKey or Newark with all the components required.
Harleyd315
Denville,New Jersey
Generator build
I have been working on this a while and now its up and running. Took an old frame, a rebuilt 003 engine I won, and then added some new modern parts. This is a 16kw stamford type generator with a solid state AVR. Only single phase but puts out 240volts @ 65 amps and the engine doesn't bog down a bit. I still have a couple of quirks to iron out but some parts are enroute and should have it complete next week.
Harleyd315
Denville,New Jersey
Aluminum tank, 17 gals. I wanted bigger to give me almost a full 24 hours of run time but I couldn't find one with the space I had available. I am however going to build some type of aux fuel setup to feed it off a larger tank in the future.
gimpyrobb
dumpsterlandingfromorbit!
27,786
755
Cincy Ohio
Thanks, I need to tweek that center hose. It gets in the way of the filter retaining ring. I also installed Special Ed's(spedmon) oil filter kit. Eventually, I will get to install Jimc's label kit!
