- 205
- 27
- 28
- Phoenix, AZ
Hello,
I have one of the early prototype M939A2s with the high top roll bar / gun mount setup.
http://www.steelsoldiers.com/showthread.php?108888-M923-with-roll-cage-and-tall-hardtop
It has the 3500SP Allison push button transmission. Supposedly this was in the Oshkosh MRAP also. It only has 4 of the "6 gears" available. I talked with an Allison dealer and her looked up the transmission build specs and said it looks like the "servos or???" in the bottom of the transmission for the 5th & 6th gear were not installed. Not sure what it would take to put 5th gear into working order other than a trip to the Allison dealer and some$$$. Question does the Oshkosh MRAP have 6 gears available? Right now with the 4 gears enabled it cruises at 60 much like a normal 939
Also mine does not have the center platform between the seats. I need some dimensions to make one or if someone is removing one from a truck that would be better. Other items are the dash has tape on everything and permanent marker identifying what the lights and gauges are for. Trying to see what some of the differences are in my truck and the "production" truck / kit are. pictures and related anyone..
THANKS!
THANKS!
