Cam Morehead
- 0
- 0
- Westminster, SC
I think I am dealing with a fuel problem. The truck cut off going down the highway. I let is sit for an hour and it started back up. It has done this 3 times now. I found a kinked hose from the discharge side of the selector valve. I decided to take the fuel line loose from the discharge side and the passenger side fuel tank. I do not use the driver's side tank. I hooked the line up from the passenger side tank and plumbed it straight to the inlet side of the fuel filter. I did not bypass the selector valve for the return line. The truck ran rough, like it has been, for about 2 minutes and then cut off. This is not what it had been doing..... Now the truck will not start and if it starts it only runs for a second and cuts back off. Do you have to bypass the selector valve for the return line also? Can this thing suck air if I do not plug the open holes on the selector valve? Should I just bypass the selector valve for the return line also? Thanks, Cam
