welldigger
- 15
- 38
- Benton LA
The deuce tranny weighs as much as an entire yugo.
Not sure whether to take that seriously or not...
Haha, that's what I was thinking myself.The deuce tranny weighs as much as an entire yugo.
No need to slam anybody. We are curious what car used that transmission, that's all. Nobody seems to be able to find any info on it other than its use in trucks.Considering that this transmission has been in production since the 1950's perhaps you should take some time out and investigate this yourself.
You are not stupid enough to think that this transmission was designed specifically for military usage, especially since most were built in England, but then again, someone does call you "general".
You must have earned that from all of your catchy 3 word posts.
I think plenty of us have looked into this and come up empty. If you would be so kind to bestow your knowledge upon us, without being condescending, we would appreciate it.Considering that this transmission has been in production since the 1950's perhaps you should take some time out and investigate this yourself.
both syncros are on the mainshaft which can never turn faster than the drive shaft, so i doubt anything other than just an old trans failing. chain reaction destruction sometimes follows.I had a similar incident happen to my deuce trans in 2005(?) on the way back from Aberdeen,except it lost a total of 34 teeth on 4 seperate gears.
It appears the driver I had in the deuce shifted from 4th to 3rd on a downhill coast instead of 4th to 5th.
All I can guess that happened was the 3rd synchro cage exploded,either from excessive speed or metal fatigue.
It actually cracked the main shaft and the trans case.
Thanks for your help. Have a nice day!Considering that this transmission has been in production since the 1950's perhaps you should take some time out and investigate this yourself.
