soldierman79
- 0
- 0
- San Antonio, Tx
Cranked up the M1009 yesterday and went back inside to let her warm up. When I came back out there was a small puddle of diesel fuel on the driveway.
It appears to be coming from the center seam in the fuel pump, from what I can tell.
So, before I replace it, I wanted to ask y'all what you thought. Should I go with an electric pump? If not, any tip for replacing the original manual pump? Will I need to bleed the lines after I replace the pump?
