M1009 Receiver Hitch
lindsaym
AK
Looking to buy some toys in the near future that will require a trailer. Is there a particular hitch that fits the M1009. And what is the cost/ length of time required to install? Thanks!
doghead
4 Star General /Moderator
1,179
There has to be 100 threads covering this with great detail.
You could not find them?
lindsaym
AK
Sure, i found some, each with conflicting information - especially in regards to what kind of hitch to get - and a bunch of terminology/steps that were a bit over my head. Found plenty of stuff on Google too (prior to posting), led me to similar forums. I'm not an expert, just looking for some help so I don't order a hitch, have it shipped to Alaska, find out it doesn't fit, and be forced to spend a wad of cash having someone make it fit. Isn't this an open forum?
doghead
1,179
How do you suggest we eliminate conflicting information this thread?
ReubenJames
Martinsville, IN
I put on a Draw-Tite last summer and it was a pretty straight forward install. Hardest thing was getting some the old rusted nuts to break free. Just used plenty of PB Blaster and take your time. You can find some good deals on them online. Good Luck.
swiss
856
Oakwood, Ga
73M819 just put a curtis on my M1009. I think that all the the receiver hitches all have challenges. The curtis is a nice hitch and would bolt up to a stock k5 in less than 30 minutes. For a M1009 expect 3-4 hours dependant on your approach.
Approaches
1.) Leave hitch assembly in place and remove pintle. This is cosmetically nice but requires the following
a. cutting off safety chain hooks
b. removing cross bar across bottom of bumper
c. removing pintle
The back holes are in frame but you have to fish in the carrige bolts and lock. Then you have to get the bolts out that hold the hitch assembly, bumper and frame and get the new bolts in with the receiver.
Approach 2:
Remove current pintle hitch assemble. Does not look as nice but in some cases if you can not get off the pintle I think this is the route some people have taken.
No matter what approach you take plan on 3 times as long. It is not a quick bolt up.
lindsaym
AK
I found a user on another thread who posted a pic of a pintle/ball combo that can be bolted in exactly where the old pintle is. Any draw-backs to this? I sent him a message but no response yet. It looks sound in the pictures, just not sure if some civilian trailers would fit. If that's not going to work, I will purchase one of the brands mentioned above. Thanks, guys!
swiss
856
Oakwood, Ga
Yes that will work. Please note below:
The combination pintle/Ball hitch assembly bolted to the bumper is subject to how good your bumper and associated bolts strength, age etc. It is an okay design, but not rock solid and for obvious reasons the above should be inspected and or replaced.
It will work, is easier to do, but limits you to one, 2" ball size. That does not fit everyone's mission in some cases
73m819
325
gainesville, ga.
YES on the draw back, that is NOT the strongest point, very weak point to pull with, when WE pulled the cross bar, it was bent, the pentle mount is basically a BUMPER MOUNT, this why the CART hitch (a frame mount) was put on.
If your going to do it, do it right
ODFever
Madness Takes Its Toll...
73
Orlando, FL
With my setup, I could use an adjustable height receiver to handle trailers that sit taller than my 18' flatbed. I've never tried fitting an adjustable receiver on my hitch, but I'm pretty sure it would work.
swiss
856
Oakwood, Ga
OD that might work, you would have to get an extension/long receiver to go out far enough to clear the pintle as you go up. If found it was easier to have the receiver which allowed for my pintle hitch, normal ball hitch, bike rack, future winch rack to all go into one unit.
doghead
1,179
Would you like the conflicting posts deleted yet?
