chief1983
Saint Charles, MO
Fixed a leaky yoke! Couldn't believe that was the problem. Put on a replacement yoke, but in the meantime I've used NAPA ultra black silicone sealant on the original one, and it seems to be holding, so now I have a spare.
rsh4364
15
greensprings ,ohio
For the first time in 2 1/2 years and 23k miles my 1009 failed to start,I don't blame her tho,its been pretty cold here lately and havnt started in 3 days.It was 5 last night with windchill of -10.Guess its time for a rebuilt IP and a block heater.I also forgot to dump in fuel additive last fill up.Im getting no smoke and oil looks feels like molasses in January..not in color but consistency!
408
Colo.
If you fuel hasn't completely gelled, which I doubt it would do at just those temps, get some heat on that block, charge up your batteries, and I bet she fires up after groaning at you. You might give this a try too:
http://www.powerservice.com/d911/
rsh4364
15
greensprings ,ohio
power service additives is what I normally use,dumped 8oz winter and 8oz 911 in tank,pulled aircleaner top, shot with 2 seconds of start fluid and she fired right up,instantly,I have manual glows and did not use! Thanks.
rsh4364
15
greensprings ,ohio
Honestly first time I ever used on any of my motors and this is my first diesel,but she started instantly.I am kinda amazed,It was probably more like a 1 second shot.
Baer
Weatherford, Tx
Ready for another starting problem? I replaced the batteries on my 1987 M1008 with mil spec and had the transmission rebuilt and everything was running fine. Then it turned cold and overnight she refused to start. However unlike rsh 4364 here in central California "cold" is lows in the high 20s. So I charged up the batteries and bled the fuel line but still no go. What do you suggest I try next... other than moving out of California (that's already at the top of my To-Do List)?
TechnoWeenie
1,669
Nova Laboratories, WA
Suspect GPs.
swiss
763
Oakwood, Ga
Need to catch up on a few projects
1. Blacked out tail lights
Fire extinguisher mount
Magnetic interior lights
Receiver hitch
5 ton tether strap for wheel chock
goldneagle
931
Slidell, LA
DH starter relay mod completed. (harness was hanging down with a new relay on it. The olde relay was still attached to the back plate when I lowered it down from the dash.) Since the relay attached to the harness was "new" not the original, I was not in a rush to replace it. Seeing the relay hanging above the accelerator was a constant reminder that I had to do the mod. Sunday we had a Sunny day (finally) so I replaced the relay and secured the backing plate under the dash. Another project out of the way.
Next is the fuel filter upgrade. Found the same FM100 unit that Gimp sells but had the heater kit and water sensor kit included for $20.50 shipped. Got a case of NAPA Gold filters in 5 microns for $21 shipped. Just have to figure out the color code on the wires feeding the water sensor. 3 wires (red, black and yellow.) Need to adapt the wires to the existing wires on the truck harness. Anyone know the wiring that feeds the existing fuel filter housing?
epitts
Terre Haute, Indiana
The best answer to give is too check the TM, that way you know for sure!
RobM36A2
9
The Netherlands
Went on a trip to Amsterdam. Enjoy lights on houses and afterwards blasting through all the tunnels there. :driver:
On the way home needed to fill up on diesel, because I was running on fumes..
Just before the gas station my transmission decided to act up.. Just made it to the station, filled up and went on my way.
Christmas morning decided to check the level of ATF.. ****, nothing left on the dipstick.. So put some leftover ATF in, about 500ml, not enough, I know.
Checked again, still nothing, looked underneath, drip drip drip.. A cooling line is leaking..
Is it possible to unscrew or tighten the line from underneath? Already found out it's the bottom one.
This morning tightened the lines from underneath.. difficult to get there, but it worked.
Started the engine, no dripping. Filled up the tranny with in total 3.5 litres of ATF. The little green monster rides again! :)
Also changed out the rear side markers with LED's from my Van, I need to take out everything with value, because they want to take it away..
The inspection thinks my Van has an illegal VIN-number..
Baer
Weatherford, Tx
Does the starter thread ever stop? I just left the extension cord trailing from the shop out to the M1008. Now waiting on UPS to bring me my mil spec GPs and GP relay. The good news is I was able to find mil spec GP relays on Ebay at a fraction of the cost for make due products at the local auto store.
