HETvet
- 6
- 18
- Bedford, texas
The trans swap is going to need a new converter. Any one running a lock up converter? How did you get it to lock up? What about the shifting pattern, How did you change the gear position display to show the correct gear pattern?
Has any one also swapped in a NP205? How did you get the trans tail housing for a 4x4? What method did you use to get the bolt patterns to match?
I ask because I have the T-case at home from a friend who didn't need it any more. And I have the transmission at home as well, from a wrecked vehicle. Its a good case as far as I can tell. The vehicle didn't run, but was running before the accident, so it should be in some form of running order.
The T-case I want to install due to the fact its gear driven and not a chain drive. Its a GM factory unit if that helps.
