g2065g
- 0
- 0
- Central Washington State
I got my deuce a couple of weeks ago. I thought the wheel cylinder needed rebuilt as there were no brakes and it looked like a leak on one of the rims where you would expect for a leaking cylinder. After a few hours to get it all apart(first time) it looks like the wheel cylinder is fine. I pulled the outer flange/axle, got the hub/drum off and had a look. There was gear oil mixed with the grease. It looks like the housing had gear oil leaking onto it also. So I assume both seals are bad. I bought them so will replace them regardless. The bearings look OK to me. There is a small amount of surface rust on the inner part of the inner bearing. Otherwise they really look good to me but I am not an expert on wheel bearings. The drum/hub are filthy and I will be cleaning them up and measuring the drum.
Pics & questions.
Do I need to clean all of the gear oil out of the outer bearing or is most of it out of there ok? I wiped them down real good but there is still a bit in them. I thought about soaking in gas or something. Suggestions?
Do I need a special tool to seat the inner seal against the housing or will a bit of grease and pushing it on with the bearing work?
I haven't take them(hub/drum) apart and figure I probably should just to get them both clean. Thoughts / suggestions?
The pads look like they are in good shape. They were coated in a good amount of gear oil. Can I reuse them? Can they be cleaned enough by soaking them in something(gas or some other solvent)? Or should they be replaced?
Any tips, tricks or suggestions i.e. be sure to check this before reassembly, are appreciated. I will look in the TMs(and search other posts) for torque specs for reassembly but if anyone wants to post them feel free.
I am sure I forgot a question or three that I planned on asking here but this should do for now.
Thanks for looking.
Pics & questions.
Thanks for looking.
