sandcobra164
- 295
- 83
- Leesburg, GA
Trying to recover an M818 today and failed miserably. I put good batt's in, hooked a slave vehicle to it, turned on the battery switch which provoked the air buzzer, went to start and nothing. I am getting a click from the protective control box and the voltage is dropping maybe 2 volts. Trying to jump the posts on the starter solenoid does cause the starter to spin but I can't hold onto it long enough to get it to engage the flywheel. Which direction do I need to be heading to figure this out? The voltage gauge is on the low side of the green and barely falls into the yellow when attempting to start. I checked the connections at the starter and they are tight. Help is appreciated, thanks!!!!
Joseph
Joseph
