TucsonVTXF
- 4
- 18
- Tulsa, OK
just did my first run under load. I can run my whole house including the AC and the mep is only running at 50 percent load so I have plenty of power!! my concern is that it sounds like I have a miss under load and I an getting blue smoke from the back exhaust. the exhaust temp was 198 on the front exhaust and 240 on the back. would one think that I have a bad injector? broken rings? my oil pressure is 40 psi when warm and under no load I have no miss or blue smoke... I do not have a compression tester....
