What is the max weight a M923a2 can handle
gem1410
44
TOMS RIVER NJ 08527
A friend of mine wants to run a M923a2 with a big plow blade and large salt spreader--He says fully loaded the truck would weight 50000 lbs--Would the axles and tires handle this weight--what is the max load for the front axle----I know the gov only rates this truck at a gvw of 31550lbs--
1,128
Front axle max rating is 9,390 I think.
Will it do it? Probably.
Will your friend get sued into oblivion when there's an accident and the insurance investigators find out he's driving a truck that's overloaded by 10 tons according to the manufacturer? Probably.
jcappeljr
27
Delta, PA.
I have put commercial dump bodys on 5 ton trucks,for off road site trucks.And loaded them with 20 tons of dirt.They will handle the weight.But I wouldnt recommend it for on road use for legal and safety reasons..
ichudov
15
Chicagoland, IL
Do not be a chicken. If your truck gets in an accident and it is your driver's fault, you will get sued into oblivion regardless of overload issue.
That said, I personally would not put more than 10 tons of weight on it.
jcappeljr
27
Delta, PA.
Yes,20 ton with no issues.Over the past 15 years I put together 4 trucks with 14' dump bodies.These trucks are way under rated for there weight capacities.
4,744
40,000 pounds with no issues?
I can see it from an axle perspective. The front axle is rated for 12K. The tandems 44K. And those are the "safe" ratings. We all know that the military under-rates their hardware on purpose.
Is it wise? No, I can't say that though...
