TucsonVTXF
- 4
- 18
- Tulsa, OK
where does fuel cap gasket 0110-0419 live? the ipc shows under the spacer in the head but that spacer looks thin and I don't really want to pull on it... any one have a photo of the spacer removed from the cylinder head between the heat sink......
definitely remove all 4 of them and have them gone through. i thought mine was running great too until jerry did them. when i got them back it was a totally different generator. there are 3 gaskets per injector you will need when you put them back in.
