- 1,962
- 223
- 63
- Arizona
Sure!Awesome pics, keep them coming!
The air filter, out for cleaning. Note the coke can and 5 gallon bucket for size reference. I think almost every other air filter I have could fit easily inside of this one.
The air box where the filter lives.
The power steering reservoir. Note the coke can for reference and the size of the lines coming from it.
The various circuit breakers inside the cab.
A shot rearward from under the front axle. You can see the very large transfer case as well as all 5 gigantic air tanks.
The #2 axle (1st of the rear tridem) You can see how the air brake chambers are above the axles to increase ground clearance.
Here you can see the massive transfer case to #2 axle drive shaft as well as the very large trailing arms.
