- 3,222
- 392
- 83
- Tonopah, AZ
Yes I do, Pm me what you are looking for. I have a full set for the wrecker.M35A2-AZ, you have some snatch blocks for the wrecker for sale?
I have a Whiffletree and the gondola cover frame bows also.
Trailer convertor dollies are useful, sure, but there are some limitations and compromises there too. Was actually thinking that it might be cool to turn an M103/5-type trailer into a convertor dolly that I could then mount beds and boxes on, in addition to the odd occasion when I might actually want to use it as a convertor dolly.If you get a trailer converter dolly, you won't need to put a 5th wheel plate on a truck. Any deuce or 5-ton with box or cargo bed, even the wrecker, could pull a semi-trailer.
All good points. Thanks for taking the time to compose such a thoughtful post, but we've done our homework and we've got the registration stuff handled.I looked into doing this several years ago and decided it would be very costly and cause issues with insurance and the CHP/ DOT.
The first issue you have is most, if not all, A2's are not old enough to be registered in California as historic.
The ability of the truck to swap the bodies will prevent you from registering it as a house car.
If the truck is not historic or a house car, motor home, you will be subject to CARB regulations and need CA numbers.
It is not legal to drive A three axle vehicle over 6000 lbs with a class C license in California.
With a fifth wheel on the frame the truck will need to be registered as a tractor.
Interesting. Will have to go poke around and find some examples. Thanks.There are basically four relatively easy ways to swap the truck bodies.
The first way is using a winch and tail roller. This is the way they do it in the oil fields.
The second way is to use a roll off like the trash companies do.
The third way is the PLS system the military uses. This is based on the European hook lift roll off.
The fourth way is European swap body setup. The body is connected to the truck with either ISO locks or special locks. Each body contains four landing legs that extend from the corners of the body. The body is removed by either raising the truck using airbags mounted to the truck frame or a combination of raising the front with airbags ad the rear with the air suspension.
Though in Adam's case he has experience it turning MVs into other things mainly RUST.I bought the wrecker bed from M16ty. It was in excellent shape except for the paint. And it was a royal PITA to get the bed, and then install it on another truck.
I highly recommend leaving the wrecker a wrecker.
Depends on the vehicle, but we've registered some as historical vehicles and others as motorhomes.How do you plan on doing the registration?
What size sheve, or maybe I should ask, what is the max cable size allowedNice!! I use my wrecker all the time.
You need any Snatch blocks for your wrecker?
I think I have a single and a double for 3/4 cable left.What size sheve, or maybe I should ask, what is the max cable size allowed
for the units you have sir?
