GreggVA
- 4
- 8
- Chesapeake, VA
Issue: My starter continued to run after the truck was turned off and think I lost a bit of magic smoke.
The truck:
1985 M1009 with 27MT starter
Doghead relay mod
ST85 GP relay
My truck had been turning over very slowly and the batteries were fine so decided that the starter needed to be rebuilt. I took it to a shop to get it tested and they ended up rebuilding it instead so got it home and installed it. Nose cone stamped no shim so none were used, back bracket is in use, followed TM and torqued to 33 ft
I just finished installing and started for the first time. Very quick to start up and initially did not think there was any issue. After about 30 seconds, I started hearing a whine that I thought was bearing noise from an alternator. When the fast idle kicked down it was apparent that the noise was from the starter area and some smoke started rising from the firewall area. I quickly shut the engine off but the starter was still going. Not turning over the engine but just spinning and sounded slower. I pulled cables off batteries - think I got the rear to front battery cable first and then the other front cable which stopped the starter.
So does this sound like a bad relay in the doghead mod, solenoid main post and S post wires touching, bad solenoid, other? Do you think I will have to rebuild the starter again?
I briefly touched the battery lead back to the battery and the starter started a slow whine again. Any ideas on testing or where to go from here?
Thanks!
The truck:
Doghead relay mod
ST85 GP relay
Thanks!
