Mercunimog404
Banned
- 352
- 0
- 0
- Carson City/Nevada
Yea the hand throttle in my truck is in the exact same spot.February 7th, 2014.
Mercunimog:
The S404.114 (Swiss) I have, SN 446, and her sister #443 (in the Dallas,TX area), both have the hand throttle up on the metal hood above the engine, just behind the radiator top tank and to the left of the choke knob. The only other thing on that cover is the turn signal switch lever and the map light with the retracting cover to turn it on., and from what I have seen of these two 1963's they were pretty much unaltered from built. The only minor difference between 443 and 446 is that mine has the VDO wheel position indicator attached to the steering column under the steering wheel to give the wheel direction of their point, and the other truck did not have this device.
The levers on the floor from L to R behind the engine cover, between the seats are:
1. Fuel selector valve handle, Main, Reserve and "Off"
2. FWD shifter & lock lever
3. Handbrake lever
4. Main shifter 1-6 gears
5. over by the passenger seat "F-N-D" lever
(No PTO or Winch controls present, no Ultra low range lever either)
Purely stock 404.114 from 1963 according to the original German operators manual, and the English version manual covers the slightly later, more modern S404's just before the S406/408 production began. Apparently the Swiss Army did not want to spend one more mark on the basic truck, so they were delivered bare frame, cab and windshield, no cab cover, no cab bows, no cargo bed or cover, all of which the Swiss built in their own Army shops, so they are not standard when compared to the German trucks. The Belgians either had the Swiss build similar cab roofs and cargo beds for them, or they copied the design, as their trucks are very close to the Swiss S404.114's in general appearance and details.
It's kinda hard to imagine where the crawler gear lever is. It comes out underneath the forward revers and is bent so you can grab it on the right side of the forward revers lever. You push it forward to disengage and pop the forward reverse in neutral then pull the crawler back to engage it.
