- 671
- 151
- 43
- International Falls, MN
I am needing to replace all of the torque rod inserts on my deuce. While searching around I have found the normal style (which I thought was the only style) from the various vendors for various prices. I found on Erik's, what he has listed as new style torque rod inserts that are a ball and joint style instead of the molded rubber with bolt through it. They are a bit more expensive but, the concept seems that it will last longer and hold up better. Has anyone used these? Also what are your thoughts and opinions on them considering that they are more expensive. I have attached an image from his website.
