vtdeucedriver
- 38
- 48
- Vermont
More pics
You can figure on replacing all the rubber hoses.Well I found the air leak, turns out the front driveshaft had rubbed on the hose to the transfercase and it split down the side, and th other one had so I got two brand new hoses. Got the fuel tank on today (a 30 gal off of an old pickup but it's better than the 5 gallon can). I found out the temp guage works and finally covered up the radiator good enough to get it to warm up nearer to operating temperature. I learned that the distributor cap is far from waterproof and if you powerwash the engine, it won't restart until you take it off and dry it up... Anyway, having a great time learning everything the hard way haha, but its been fun, these trucks are great to work on.
This is the info you want!!! He knows the 6602 and probably has the sweetest running 6602 around..........I know, ive followed it many times. The OD trans he talks about is also in the 800 series.Unfortunately, it's not the distributor shaft that is off. It has a flat/off center key that will only go in one way. It is the adapter below it that that is off from the drive gear. Don't think that is accessible except when you drop the pan. For the distributor itself, it looks like from your picture that the top cover was cut out to use a civ. distributor cap. A fresh cover, new cap and other internals will make it like new- then worry about the re-timing when you have other reasons to go below! TJ Murray, Memphis should have the parts.
The 6602 will run rich with the Holly- there was a replacement carb kit for the engine when the Holly was no longer in the system. I believe it was a Rochester, and it does a better job of fuel management. Won't choke anyone following you quite as bad. Again, some of the old time dealers could still have that carb available.
The engine is a winner- can run at full output all day long, with more torque and less noise than a multi. Might also consider the 5 speed Spicer with the 5th OD (a bolt in), as used in the Mack engine versions. The low end torque and wide rpm range make for a very versatile power plant.
