JasonS
- 144
- 63
- Eastern SD
The farm tractor does not. I'll try to find the link discussing this...Do the road and farm tractor engines use the same rods.....
Pics attached but don't show the rounded block on the later TD block.It turns out that there are two different TD military blocks. The LD and early LDT blocks that I have are squared off around #6 while the later LDT are rounded on the passenger side with two ribs extending vertically on each side of the frost plug at the rear of the block. The tractor pulling crowd has noted a problem with #6; wonder if the ribs were added to correct a known problem? I'll add pics tomorrow....
$18.37 here:JasonS,
The 25 USD pr bolt was for 500-1000 units or less. So the more people that can get behind this the better.
Did the injector fit the engine?Be careful when purchasing these parts. I would even say call before you order and check on the size of the bolt. I purchased an injector for an Oliver 2150 Hercules and it does not look anything like the stock ones.
I wonder if they sent the wrong part. The pics in this thread sure look like should have the same injectors: http://www.steelsoldiers.com/showthread.php?73830-Oliver-2150-with-multifuelBe careful when purchasing these parts. I would even say call before you order and check on the size of the bolt. I purchased an injector for an Oliver 2150 Hercules and it does not look anything like the stock ones.
