JasonS
- 139
- 63
- Eastern SD
This thread suggests that White 2150 had a MM 585 engine,not Hercules: http://talk.newagtalk.com/forums/thread-view.asp?tid=103767&DisplayType=flat&setCookie=1
Why would that suggest a different injector? The head castings are supposed to be the same.Considering the tractor used a roosamaster pump I can't say it would surprise me that the injectors would be different.
Casting yes. Doesn't mean the machining is the same. It could be. I don't know either way.Why would that suggest a different injector? The head castings are supposed to be the same.
