New to me '86 M1008
cpf240
Free in Northern Idaho
... I replaced my wiper motor with one from Auto Zone. It didn't have the washer pump. Their computer didn't show one with a pump, what's up with that?...
What model year did you tell them it was? If you said '86, then the computer is correct. The CUCVs were all built to '84 specs, no matter what year they were actually built. So, in '86 they didn't use a wiper motor with the pump built in. You need an '84 wiper motor, if you want the internal pump. I would just get a washer bottle from the junk yard that has the pump in the tank. Much better performance. You could also put in one of the aftermarket in-line washer pumps.
Warthog
232
OKC, OK
You really need to start posting your pictures here and not photobucket.
Warthog
232
OKC, OK
Some parts are not the same as the civvy version. That is when the TM parts manuals come in handy. All the GM part numbers are listed. Some of the part numbers have been updated or no longer available.
smokeeater495
Northeast, Indiana
I pulled out the rubber floor mat and then cleaned up the floor. I found lots of sunflower seeds and a few spent 5.56 cases. What is the square metal plate on the floor of the passenger's side?
