I switched to a 1.8 spray tip for the thickness (even though thinned) to get the coverage with this product - for those taking notes.
OK - seeing how the weather was fricking awesome tonight - I started with the interior (I was honkering to see it come to life) and it still needs the second coat - I left the window and passenger door open to get a good dry out tonight as the weather is getting better into the weekend - I think she will be good like that till tomorrow night.
Re-sprayed a second coat on the hood as well and gave the drop sides another coat - it takes a little bit more for me to be happy with an end project.
Advised Swiss I will pick up a second gallon of 34094 green tomorrow on the way home as its suppose to be in the 70's tomorrow - so anything on the interior you see still in tan will be dead as nails when I am done and into GREEN.
When the slacker ever decides to show up to help remove the cargo cover - I will get it pressure washed on the inside and finish the dropside framework - as well in between the cab and box.
Here are a few pics
posting pics on whatever change has been make totally sucks.
