- 6,858
- 685
- Stratford/Connecticut
I recently won a mep-925b gen. I have been reading the TM and searching the net for more info. The TM lists the spin on oil filter as 541.050.2E, I looked up the filter for a generic Farymann 43F which is listed as a HW1103. Does anyone know if there is an off the shelf Napa cross reference for the oil filter? The fuel filter is listed as a 32260 which is a cartridge filter. The filter housing top is mounted and I have a plastic screw-on ring but no bottom housing piece to hold the filter. It looks like there is supposed to be a hose that comes off the bottom of the filter housing also. The TM lists the housing as 96-9165. Does anyone have any knowledge they can share on this? Here is a picture of the fuel filter area with plastic ring. I only see a fuel feed it would appear the return is recirculated internally. Thanks in advance.
Will
Will
