TexAndy
- 15
- 38
- Bee County, Texas
The problem item is the front axle engagement switch on the dash. I've got one that just keeps hissing air out both side holes and through the front (around the lever).
I've taken it apart and cleaned both the piston and the valve body and replaced the o-ring on the piston. Still, no joy.
Hooked up my shop air compressor to the input line to the t-case, so I could hear the transfer case to front axle cylinder engage when I pulled the trigger on the air hose. And it makes an audible clank. So I'm pretty sure that much is working.
Has anyone here been able to successfully rebuild one of these air switches?
Failing that... is there a commercial equivalent I could use, instead? Or something that wouldn't be terribly hard to modify?
