welldigger
- 15
- 38
- Benton LA
Yes
You know this is getting beyond my comfort zone as far as mechanical work. I am comfortable taking the bolt out and checking the plunger. I might need more expert help if it requires digging into the IP. (I don't want to pull thinga apart and have parts falling into the dirt where I cannot find them again.)the plunger should move about a 1/4 inch. If it doesn't move, you can tap it down lightly and see if that works. If it goes up and sticks again, you probably lost the button off the bottom, and need to pull the head.
It's not nearly as scary as you may think.You know this is getting beyond my comfort zone as far as mechanical work. I am comfortable taking the bolt out and checking the plunger. I might need more expert help if it requires digging into the IP. (I don't want to pull thinga apart and have parts falling into the dirt where I cannot find them again.)
GE, spraying and then starting is bad mojo. You got to spray while the motor is turning. I usually open the pass windshield and spray with the motor turning over. Works mo-better, and you don't have to worry about launching a rod.
I had my neighbor help me yesterday -so he sprayed once I started cranking.Yeah, what he said. In my case I just open the passenger side door and stand on the step and spray while cranking the motor. Crank first and while it is cranking then spray.
Spray then walk around and push the start button may give you an experience you didn't want, replacing the motor being the worst....
Kinda of a long trip for Gimpy. Would love to have Gimpy work on some of my MVs. I might even learn something. I was hoping for someone local so the travel expense would not kill me.For a fee I'm sure Gimpy is available.
Thank you for your confidence in my mechanical skills. I keep thinking back a few years ago when John Lambert tried to repair/replace an IP in his Deuce. Had a couple of mechanics trying to install a new IP. Ended up installing it off-timing and that resulted in all kinds of headaches. I know a year later he still did not have the truck running!Been reading this thread. Gotta tell ya GE - you can do this. Get some clean towels - look at the tools needed for the job and slowly tackle it - I have done Dinger65's a couple three times now because his truck just sits.
Its not simple but dang near close to it - once you get past the couple first steps you'll know when to stop - but its not reason to not try to tackle it - its a learning curve.
Those above have given the steps to take to at least check it out - go for it.
Next thing we wanna hear is that it is purring like a kitten (kittens only purr when they get stuck in your engine fan firing up the truck BTW)
It sure is! I learn something every time. I hope my brain doesn't explode.opcorn:It is always educational to follow a troubleshooting thread
You have been great at giving clear instructions as well as excellent photos. I will test out the plunger movement as soon as weather permits. I will keep you guys updated on the progress.GE, look at it this way. There are steps 1-10 to see what is wrong. We can walk you through starting at 1 and you can stop at any point. Right now, we are asking you to check things that CAN NOT do any damage, they are only trouble shooting. If you check the plunger and want to stop after that, I understand.
What you will need to do now is:
1, pull the center plug/bolt(whatever you want to call it).
2, put a wooden/plastic dowel in there and have someone turn the motor over while you put light pressure on the dowel.
3, if it doesn't move, tap it lightly to free it up.
4 if it moves up and down about a quarter inch, put plug back in and see if she starts.
5 try ether, a minor whiff(sometimes thats all thats needed).
6 (still doesn't start?) time to pull head. If you want to stop here so be it.
I understand its intimidating, but as of right now, you can consider the truck broke, you will not hurt it anymore than it already is.
If its more than you can handle so be it. I do not blame you for being strong enough to admit it. Sometimes its best to let others step in.
