Proper battery cable installation
firetruckmatt
Trenton, NJ
I repair fire trucks and one of the departments I provide service for recently purchased an M35 A2. There has been a Kussmaul brand (common in the fire industry) 24 volt battery charger installed and it does not seem to be operating properly. It looks to me like the batteries are not properly installed/wired. I tried looking through the TM's but couldn't find anything. Anyone have a diagram, or some info that might help me out? Thanks a lot for any help and/or advice you may be able to provide! Really cool site by the way.
gimpyrobb
dumpsterlandingfromorbit!
27,786
755
Cincy Ohio
The wire from the frame goes to the first battery ground. The (+) positive terminal from that battery connects to the second battery's ground. The positive from that battery connects to whats left. I will PM my cell number if you have more questions.
firetruckmatt
Trenton, NJ
Yea, that's how I thought a normal 24 volt system would be wired, I didn't know if these trucks were wired different for some reason. This particular truck has the two ground terminals jumped together and wires coming off of each of the four terminals going to who knows where??? I think I am going to have to just tear it apart and start from scratch. Thanks a lot for the help!!!
SteveKuhn
Hasbrouck Heights NJ
Your description sounds sorta like my friend's M37-turned-fire truck where they tapped off the 2 batteries individually for independent 12v stuff. You might consider that.
Steve
Warthog
232
OKC, OK
From the TM 9-2320-361-20 Unit Maintenance Manual, page 2-77
On many trucks (not all) there is an additional heavy cable on the first negative and last positive terminals. Those extra cables go to the slave port on the side of the cable. The slave port allows for jump starting other similar trucks or equipment
firetruckmatt
Trenton, NJ
Do these trucks call for wet cell batteries or dry cell batteries???
Warthog
232
OKC, OK
Usually wet cell, but the latest is AGM (absorbed gas mat). You can use just about anything as long as the CCA is high enough.
The stock battery is a 6TL (or some version). Many of us have used the Group 31's as replacements. Easier to find and they fit the box.
whiskey357
Banned
168
chicago,ill
sounds like each Co. that provides charges is somewhat different for each installation....go with the TM...I have and it works.....(wife hands me my glasses at the right time ...Best of all on this good luck)
m-35tom
222
eldersburg maryland
does it start and run? if the negatives are tied togeather it has been changed to 12 volt.
