Normal top speed for Deuce
rwminck
Florence SC.
Took my M35A2 out for a ride and my top speed on stock 9.00 is about 50 mph and that is on a flat and to the floor. Is that normal? Wonder if I am starving for fuel?Thanks
mactiredearg
Denver, Colorado
let me beat the search nazis to it: This has been covered repeatedly in threads, please use the search option on the top right of the site.
That said, yea, that might be a _little_ slow but its basically in the range for the top speed of an M35A2 on 9.00s. I think 55ish was my top speed on a flat, with a tail wind and an optimistic speedo.
The only things built for the military that are meant to go fast have wings and even most of those are comparatively slow...
You might play with your fuel setting, but make sure you have a pyrometer installed (again search is your friend).
ATPTac
Charlotte, North Carolina
Fuel isn't going to get you faster than that, 50-55mph is the top speed for a Deuce unless you put bigger tires on it or an OD gear in it. At that speed you're limited by gear ratios, not fuel.
ATPTac
I should add that's keeping the RPM's at safe sustained levels. Also, download a speedometer app on your phone and check it with that. These speedometers aren't the most accurate in the world.
mactiredearg
Denver, Colorado
Good point, "top speed" in these things should be thought of in terms of sustainable RPMs, regardless of fuel setting or actual ground speed.
The sticker on the tach (if you have it) will say 2700 RPMs is your red line. But that is really your maximum rev limit, not your maximum hold @ RPM. Hold it there often or for long and your top speed will become 0.
Probably the biggest adjustment I had to make when I started driving these trucks was to the top speed. Now I adjust my ETAs and enjoy driving the coolest vehicle on the road at the time...
welldigger
Benton LA
I would download a speedo app on your phone or get a gps unit an verify your speed before you panic. My speedo always clocked a bit slower than what I was actually going. Of course, that got much worse when I added larger tires to the mix.
muthkw25
704
Canton, PA
Put singles on it and run the same speed at less rpms, you will get better fuel economy too and if you need the extra speed it will bring you up abotu 10mph.
doghead
4 Star General /Moderator
1,185
Singles slow the engine speed?
I think you left out an important detail to make that a valid statement.
doghead
1,185
So, if I simply remove 4 of my rear tires, my truck will have a differnt gear ratio?
BRB...
muthkw25
704
Canton, PA
Its not changing the gear ratio, but when you added larger tires to a vehicle, the engine will loose some torque to rotate the larger tires. Because the tires are larger, it will take less revolutions to go the same speed as stock 9.00r20s, therefore you will have increased your top speed. The rpms will be lower at 50mph with super singles than with 395's. You will acheive more speed with 395's but loose some torque. It's a trade off.
doghead
1,185
Until now, you never stated that the tires(singles) needed to be larger in diameter!
I knew this, but your post(#10) was incomplete and misleading to anyone that does not understand what you meant to say(but did not).
m109a2
lake charles la.
Want to go fast buy something eles just got my fist ducse.I bought neils rig and I love it.I drove her over a thousand miles took almost a week butt loved it.It is what it is.
doghead
1,185
Congrats! I'm glad to hear he was able to find a buyer and one that loves it(He sure did).
