rustystud
- 2,815
- Woodinville, Washington
Usually what happens is the power goes out, my emergency lights come on (each room has lights that are battery powered) and I go out to the generators. I choose which one to use, and pull the lever up or down on the transfer switch. Then I start that generator and let it run for a few minutes. Then I go inside the generator building and pull the transfer switch to generator. Full power to the house .Can you go in to a little more detail about what you used as a transfer switch between the 2 gens and also what you have to do when switching between gens. I imagine anything sensitive in the house will have to be shut down as power will be shut off for a few moments. I was looking at getting an 002a to go with my 004a for when I dont need the extra juice.
I colored coded the cables so I knew what was what. When your pulling 2/0 copper cable you can get confused after awhile ! Yes 2/0 cable is overkill but I was required too. When we finally got power, I was given the choice of 240amp service or 480amp service. Since we are on acreage ( and I have over 60 fruit trees) we are considered a farm so I was given the choice. I chose the 480amp service. Well that means we are now considered commercial property !!! The code for commercial is way different then for residential. The inspector had his way with me, and NOT in a good way I had originally ran 1/0 cable, but that did not meet code for commercial !!!) I showed the inspector the 'NEC" book and the proper table used, he showed me the commercial table. When I said this is a residential property he said this is commercial property since we have 480amp service !!! Lesson learned the hard way
The transfer switches I used are "GE" 250 amp units. I'll try and get the model number. I believe I spent $300.00 on each. Way cheaper then anything else out there.
I also have battery chargers on each generator (see picture).
