amphi
- 1
- 8
- Onalaska, WA
Starter run-on is usually the result of a stuck starter relay or stuck starter solenoid.
The act of disconnecting the front battery (negative) ground wire, during a starter run-on, can cause the fusible links to fry. This is due to reversed-polarity feedback current flowing from the rear battery thru the driver’s side alternator or any other directly connected 12v device.
Normally 24v current flows from both batteries thru the starter to ground and back. (See illustration)
Disconnecting the front battery (negative) ground cable will make ANY connected 24v load lose its normal ground path. This load can be a run-on starter, manual 24v glow plug system, switched-on 24v radio, or a slaved 24v device such as a pump. These connected loads will now see 12v from the rear battery and seek a ground path thru the trucks 12v system. (See Illustration)
Under this circumstance the entire 12v system now sees 12v at a reversed polarity from the rear battery. The result is reversed polarity current flowing thru any directly connected 12v device. This can be damaging to any connected 12v devices that cannot tolerate a reverse polarity - like the driver’s side case grounded alternator (Gen 1), CB radio etc. (See Illustration)
The end result is usually burned fusible links thereby supposedly protecting the devices from heavy reverse current flow.
Good clean ground connections are essential in this dual voltage system.
This is one reason why a single battery disconnect switch at the front battery negative ground is NOT recommended for the CUCV dual voltage system.
